Is it possible to apply a spatial filter to a layer that is based on a points location to a polygon layer that is frequently updated? The layer would be published and used in a map application where the user would see only the points within proximity to the most up-to-date version of the polygons.
I wonder if this workflow, Spatially Filter Feature Layers with Definition Queries, would work for you?
It's a good idea, but that only selects features that intersect the geometry you select, I need "within a distance".
Gotcha. So question then - what type of map application will you be using? Experience Builder? Instant Apps? Other?Related - straight line distance or drive time/distance?
Experience Builder. Straight line distance.
Okay. So Experience Builder can do “points within a straight-line distance of polygons” using the Query widget (not the Filter widget).
Here are some steps you can try:
You can learn more about the Query widget here - Query widget—ArcGIS Experience Builder | Documentation
The problem with this approach is that the Filter Layer only supports Selected features so I would have to add another step to the the workflow where users have to select the polygons first.
The idea behind trying to filter the number of points before bringing them into the app is because there are just over 50k points that I'm trying to find within proximity to about 75 polygons. Trying to do this all within the app cause performance issues.
For additional clarification, the intended use of the app is to enable users to identify our assets that are within 10 miles of the wildfire perimeters in this layer (https://www.arcgis.com/home/item.html?id=d957997ccee7408287a963600a77f61f#overview)
Understand. So, sadly, in ArcGIS Pro, there isn’t a built-in dynamic spatial filter that continuously re-evaluates a layer as another layer’s geometry changes (including “within a distance”). I know one can do this running a series of GP tools to ultimately get to the updated list point of points within 10 miles of a wildfire perimeter. Presumably one could script the workflow and schedule the Python script to execute daily via Windows Task Scheduler. Could do the same thing in ModelBuilder too.
