Currently we do not have names for water segments (I know its not a good thing). We currently have 9k water main segments and I would like to not have to name them all individually. I have made a rule in my utility network to auto-assign a number for my sanitary sewers but those are easy because each segment begins and ends at a manhole.
Now to my real question, is there a way to assign a unique name to waterlines that are between two valves or a coupling? Some of these lines are split because of pressure change but I would like these to be named the same. I attached an example. Between both valves in the attached are all one project and material the only thing that changed was the pressure. For asset management purposes it is one item but for attribute reasons there needs the split. I would like both the selected portion and the unselected portion between the two valves be the same. Can this be done or am I better off just doing a batch appointment of a new name for each segment and implement the naming going forward?
I can edit this post for further details if needed.
