This week I had maddening issue with "The form contains unsupported data" with layers. I went into Field Maps Designer and the fields were highlighted in purple with same message. I hit the trash can hoping to just remove the field and then add again to resolve issue. It then prompted me if "I was sure I wanted to delete field" which I said yes thinking it was just the form. Then I noticed that those fields and data are now missing from database. IS IT POSSIBLE TO DELETE DATA FROM FIELD MAPS DESIGNER?!!!! Or were those fields somehow deleted prior which caused the error in the form. No idea how the data was deleted otherwise.
It is possible to remove the fields from the data in field maps designer.
Geat string discussion. I wonder how children in schools using MAPMAKER are able to handle this type of problem?
Great image! I only removed from the form. So my guess is that the field was somehow removed from database prior which caused the unsupported data issue. But kinda scary that the field can also be removed from this page. I would rather that it only be able to be deleted from AGOL layer page.
