I am working with ArcGIS Pro 3.6 and need to configure the Vertical Alignment property for map labels before converting them to an annotation feature class. However, I am unable to find or enable the Vertical Alignment option within the label properties. My objective is to control the vertical positioning of the text (for example, top, middle, or bottom alignment) so that the annotation is created with the desired appearance and requires minimal post-processing. Has anyone encountered this limitation in ArcGIS Pro 3.6, or is there a specific setting, labeling engine, or workflow required to enable Vertical Alignment prior to converting labels to annotation? Any guidance or best practices would be appreciated.
Thank You, Kamal Kant Verma
