When you add numerous feature classes or shapefiles to your table of contents they all represent as different colors initially. Need a way to change them all to one color in mass so I don't need to go to each layer and manually change it to the same color for all layers
You can just use the Apply symbology from layer tool in batch mode using the first layer as the source and every other layer as the target?
The Replace Colors command allows for this. It's available with an ArcGIS Topographic Mapping license.
Connectez-vous pour publier, suivre du contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
