Instant app "Nearby" is great. I would like when you click on the map for the address of the click to be displayed rather than a business. E.g. I am clicking on a shopping mall and it says "Subway" restaurant from the geocoder. This looks less professional and appropriate than displaying the address
@MattSund We don't have the ability to configure the reverse geocoder, but you can enabled "use map click location" to not show the address. Since this search uses an x,y search method, the address is not populated into search box when clicking on the map. This setting is located in the Nearby > Search method > Search radius settings of the app. You can set map click there and it will still hide the address when using map extent.
@BethRomero thanks for your reply. This does change the behaviour of the address search bar in the left panel - but the map pin and radius on the map still have the store name as the placed label. I'd like it to not show as a label on the map. Thanks
Connectez-vous pour publier, suivre du contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
