I've got a question around the performance of the Weighted Overlay tool. I've got about 15 rasters to process in a File Geodatabase in a performant network drive and a fairly beefy instance.
Every time I add all of the rasters into the tool, it begins to calculate something - presumably values within the rasters. This takes a fairly long time and when I try to modify the percentages, it does more calculations. Depending on the size of the rasters, I can sometimes end up waiting for hours just for the tool to load before even running it.
There is something inefficient about how the tool operates. Upon digging further using Diagnostic monitor, I found that for every raster (if I add it one at a time), it loops through the entire Geodatabase and data to perform something called "Geodatabase.Table.OpenDataset" several time for each raster.
Found it odd that it does that. Can anyone clarify what it is actually doing and how to avoid it?
