With the release of ArcGIS API for Python 2.4.3, we want to extend a huge thank you to our community. Your feedback and active participation are what truly shape the evolution of this product.
For those new to the ecosystem, our public GitHub repository is your go-to hub for samples, tutorials, and documentation. Your feedback through Technical Support and our public repository are where your voice matters most—we actively monitor the issues and enhancement requests logged there, integrating your ideas into every release cycle.
Here are a few of the submissions from you that made it into the 2.4.3 release from both the public repository and through your Tech Support feedback.
Enhancements:
ENH-000179291 Enhance the clone_items() function in ArcGIS API for Python to support passing identical Item IDs across source and destination ArcGIS Enterprise portals.
ENH-000145456 Return Z and M values using the arcgis.features.elevation.profile method in the Python API
Bug Fixes:
Map.content.update_layer() cannot apply labeling to FeatureCollection/FeatureSet layers
https://github.com/Esri/arcgis-python-api/issues/2465
Getting the dependencies of web map doesn't work depending on the arcgis active environment
https://github.com/Esri/arcgis-python-api/issues/2436
arcgis.apps.itemgraph module : create_dependency_graph picking up id of layer within webmap instead of the portal item id of that layer
https://github.com/Esri/arcgis-python-api/issues/2429
Unable to retrieve Enterprise Portal Licenses
https://github.com/Esri/arcgis-python-api/issues/2447
BUG-000181596 Cloning Story Maps does not preserve the Item ID on Enterprise
BUG-000181653 Malformed StoryMap URL property for Enterprise
BUG-000181260 Unable to create join view layer using ArcGIS API for Python View Manager Class
BUG-000179186 Query outfield map image layer returns different ObjectID than infield when using ArcGIS API for Python.
BUG-000179671 The ArcGIS API for Python buffer method on a geometry object returns a polygon with an incorrectly formatted geometry definition
BUG-000176517 ArcGIS API for Python folder.add() function does not honour the item_id parameter, When the item is added to the folder the items id is different from the item_id specified in the function parameter.
BUG-000176001 When using the ArcGIS API for Python's item.update() method to update a file, the file in the data path does not require the replacement file to have the same name as the item in ArcGIS Online.
Thanks again and we look forward to your feedback as we begin work on the iteration of the ArcGIS API for Python!
Take a look at the new features for version 2.4.3:
https://www.esri.com/arcgis-blog/products/api-python/announcements/whats-new-in-arcgis-api-for-python-2-4-3
