Hello all, I am relatively new to City Engine and have run into an issue with assigning rules to to nodes. The complete streets rule works flawlessly when applied to streets and simple roads, but it doesn't seem to work with the nodes. This is the workflow that I have tried:
-Select node
-Within node parameters, changed type to "Crossing".
-Select Node road beds tab. Assign the complete streets rule.
-Changed the start rule to, "Crossings".
At this point, the crosswalk related attributes are all grayed out and I am unable to make adjustments. Is this a limitation of the rule set or am I doing something wrong? Ideally, I would like to create crosswalks that are a part of the intersection rather than positioning them further down the street.
Thanks in advance.
