G'day all
As with many users here, I have a problem with the performance I am getting from ArcPro. It's always been a bit plodding, but over the last two weeks it's taken a real downturn. I have been through all the conceivable forums and advice on setting the machine to work as well as possible - with the machine I am using being relatively spec (32 GB RAM, RTX 3060 GPU, 2.4 Mhz). I work locally, bar the use of REST servers to hook into data and basemaps. From what I can tell it's these servers that are causing the issue, with Diagnostic Monitor showing MapServer-related slowdowns. Sometimes the basemap imagery I use (usualy World Imagery) doesn't even load and just red-Xs itself. Sometimes it is perfectly fine. However, this is only happening in ArcPRO. When I switch over to QGIS, I can bring in the data no problems with QGIS's usual alacrity.
I am just wondering if anybody else has experienced this in the last 2-3 weeks? Is there something wider going on with AGOL services? Whenever it happens I check the online service monitor and it always says the service is up and running. The only thing that has changed at my end is I have switched to Starlink in that time...in which case, has anybody experienced similar issues with this ISP??
Cheers in hope...
