I can't use the Editor widget to add related records to an attribute only table. The form is configured correctly in map viewer. (Editor.png)
The "add records" section just disappears in the Attribute Only Editor widget-so there's no way to add the repeat records. (Editor1png)
The Attribute with geometry option in Editor just shows my related polygon feature layer. So there's no access to that parent non-spatial table. (Editor2.png) In my polygon feature layer, I can add records to the related table... (Editor3.png).
I essentially created a whole series of surveys and databases for a grant monitoring program, with the expectation that I'd be able to create an app to manage the records... not realizing I'd get stopped here...
I guess I can add the other tables to the list and manually populate the Global ID from the parent to the GUID field of the repeat. 😑
Data structure: I have a non-spatial table with two seperate relates: a related non-spatial table and another related polygon feature layer (and that polygon layer has it's own related table). All with the correct relationship classes - I'm very comfortable with that.
Anyone have a solution???
