Hello everybody,
I have a problem when running my Model. It begins with "Iterate Feature Classes" which is connected to "Extract Multi Values to Points". The output is then connected to a variety of other tools etc. When running it in the Edit mode, there is no problem whatsoever.
However, in the normal Run mode (when I klick open and not edit), it always stops immediatly and tells me Error 160326 The table already exists. I have restarted ArcGIS Pro multiple times, have deleted everything that might be the problem (including everything in the Scratch GDB).
There is no other file anywhere with the same name, I even tried renaming the feature classes, made new GDBs and folders, it still happens. I really don't know what to do anymore, is this a common problem? Or is there somehing I have overlooked?
Thank you so much for any information!
