I am currently experimenting with the pretrained deep learning model Wind Turbine Detection in ArcGIS Pro.
In the past, the model was able to successfully detect several wind turbines using the same (or similar) imagery. However, since the beginning of this month, I am no longer getting any results at all. The tool runs without any error messages, but the output feature class contains 0 detections.
What I have already tried:
Tested different imagery (including Esri sample data, ~0.6 m resolution)
Adjusted parameters such as confidence threshold and padding
Ran the tool on both CPU and GPU
Reinstalled ArcGIS Pro and the Deep Learning Libraries
Verified that other pretrained models are working correctly
So far, nothing has helped.
My questions:
Is there a known issue with the Wind Turbine Detection model in newer ArcGIS Pro versions?
Could this be related to specific parameters that must be set?
Has anyone experienced similar behavior recently?
Any help or suggestions would be greatly appreciated!
Thank you.
