Hello all!
Using Survey123Connect v3.23.48 in a disconnected environment. When I go to open the application, a white screen comes up, then the app crashes. My coworker found that if you delete the 'C:\users\<username>\ArcGIS\MySurvey123' folder, the application will open as intended. But.... in order to re-open the app after closing it, you must delete that folder again, and every time you close the application. Anyone else running into this issue?
