Hello everyone
I have a question that maybe someone already knows the answer to, as the topic is well-known, but unfortunately I can't find the forum.
Does anyone have or know where I can find a widget that will insert an object based on WKID coordinates?
Ideally, it could be configured to connect to the map's edit data, but if it were a temporary object, meaning it could be inserted on the map, for example, as a pin, I'd also appreciate it. Experience Builder 1.19 (Dev Edition)
This is how I see this widget working:
The user enters:
X = 123124.66
Y = 434343.46
WKID = 2177
Click "Add point"
The point:
is saved to Enterprise GDB
appears on the map
The attribute form opens automatically
identical to the "Edit" widget
The user fills in the data and saves it
Best regards, everyone
