I'm sorry to ask such a simple question, but the system seems to fluctuate between liking me and not liking me.
I logged in as a developer, went to my dashboard, and generated a new API Key. I had this working for a bit, but then made some minor changes in code, returned, and am now getting an error 498. I verified an expiration date of a year from now, and the system even doesn't show the key being used at all, which I know to be incorrect.
I regenerated the key, replaced it, but it's still failing the same way.
One thought I had when reading about is that perhaps the key generation is not valid with the endpoint I'm using:
https://elevation3d.arcgis.com/arcgis/rest/services/WorldElevation3D/Terrain3D/ImageServer/getSamples
It's just a thought. I'm new to ESRI, and I'm surprised I cannot see any utilization when I know I was making several calls successfully earlier. At this point, the location services API key being invalid for this endpoint is a guess, but it might also explain why I see no traffic.
I'm not new to programming, not new to REST, not new to so many things, but ESRI seems to be easy - once you know the secret. I'm secret poor right now....
Thanks in advance.
