I'm using ArcGIS Pro 3.6.1 and I'm trying to COGO some survey points to create an easement. Entering the traverse points is fairly easy, we use South Azimuth in Hawai`i. The issue I am having is establishing the POB. Here is what I am doing:
1) The easement begins with "beginning at the north corner of this parcel of land, the coordinates of said point of beginning referred to Government Survey Triangulation Station "NAWILIWILI" being 2,336.47 feet South and 1,627.19 feet West, thence running by azimuths measured clockwise from true South..."
2) I open Pro and add the NGS Datasheet Feature Service. I have found the NAWILWILI geodetic control point, here is the datasheet.
2) Then in Catalog --> Databases I create a polyline feature class titled “KN_3”. I give it the projection for Kauai, NAD 1983 HARN StatePlane Hawaii 4 FIPS 5102 (US Feet) . Then I run Enable COGO on it.
3) I then go to the ribbon and open Project --> Options --> Units --> Distance Units and change it to US Survey Foot. Under Angular Units I select DMS.
4) Under Map Properties --> Coord System I keep it at what the NGS Datasheet Feature Service is, NAD 1983 (2011).
5) Then I activate Ground to Grid Connections.
6) My next step is to open Modify under Edit and select Traverse. I set the start point on the NAWILIWILI control point as seen in the red dot on the triangle below. I enter SAz, 0-0-0, distance 2,336.47'. I then enter SAz, 90-0-0, 1,627.19'.
This is where it gets off. These two survey points should set the POB for the easement. The problem is the POB is in the ocean and not where it should be:
Where it should be is somewhere near this circle:
I'd really appreciate it if somebody could give me a step-by-step on how to do this. Thank again.
