I suspect the answer to this is probably no (and may be doable with the new release) but here goes... I've got a form set up for vegetation survey, it uses a repeat section to record separate species lists at ten sample locations within parcels of habitat. I would like to also be able to record a complete species list with abundance levels for the whole habitat parcel without having to re-enter species already recorded at the ten sample points. So a section which can be pre-populated with a master list of all the species recorded in the repeat section to which abundance values and any additional species present outside the quadrats can be added. I think this can be done for a single point, but can't find anything on doing it for a set of repeats. Is this possible with the current version?
