Good Morning,
Is it possible to publish referenced services in ArcGIS Enterprise 11.5 from Mapped Network Drives (E: for example)? Can the ArcGIS account access and manage them even if the Mapped Network Drive is only mapped for the user that is use the machine?Best regards
The Service account user running ArcGIS Server needs access to the location for referenced services. The location needs registered as a data store and that registration will fail if ArcGIS Server cannot access the location.
I would recommend using UNC paths in this case instead of mapped network drives, as mapped drives are specific to individual user sessions and not system-wide. Is there a specific reason you prefer to use a network drive?
Thank you for your feedback.We wanted confirmation because it seems that it is not possible to remove the data disk on the installation in question because it is a physical disk.Best Regards
Dennis
Best regards,
