I’m trying to better understand how the Java heap behaves in ArcGIS Enterprise. I don’t have any background in Java memory management beyond some recent research, so I’d appreciate clarification to make sure I’m interpreting this correctly.
From what I’ve gathered, Java in ArcGIS Enterprise is configured to allow the heap to grow up to the configured -Xmx value. In ArcGIS Server, there is a maximum heap size setting, where the default value of -1 allows the Java runtime to grow the heap to a maximum of 25% of physical memory. However, native ArcGIS logs and monitoring tools don't provide any visibility into how much of the allocated heap is actually in use, how close the java heap is to its configured maximum, or how effectively garbage collection is managing memory.
If this understanding is correct, then:
- The javaw.exe process may continue to show a large amount of committed memory, even when much of that heap space may be in active use.
- As a result, overall memory utilization on the machine can appear high, driven primarily by Java’s committed memory, even though this does not necessarily reflect memory pressure or exhaustion within ArcGIS Server itself.
- This makes me question the effectiveness of monitoring physical memory usage alone in ArcGIS Enterprise, as there would be cases where the Java heap is exhausted, causing a component to become unresponsive or crash, while system memory utilization never reaches 100%.
- It is difficult to determine the appropriate heap size required for any given ArcGIS Enterprise component site.
I'm considering submitting an ArcGIS Idea to request that ArcGIS Monitor expose Java heap related metrics, but I just wanted to confirm my understanding first. Ideally, I’d prefer not to rely on third-party Java heap monitoring tools, though I’d be interested to hear if others are using any specific tools or approaches.
