I am a relatively new user of Survey123, though I successfully deployed a survey using repeats earlier this year. This survey was for information about each group of people encountered while hiking a trail, such as the number of humans/dogs and whether they were camping. Each encounter was recorded in a repeat, with the appearance set to "minimal" so that the label and a plus sign appeared initially. The surveyor would create a new repeat record each time they encountered a new group, which would happen intermittently during the hike.
I found that one of the most frequent causes of user confusion and error was what to do after entering all the data for a record in a repeat. There is an intuitive urge to do the equivalent of pressing "Enter" to complete the entry and move on to the next thing. If the next task is to immediately start another record for a new encounter in the same repeat, then it is intuitive enough to press the plus sign at the bottom of the repeat block and start the next record. But if they do not immediately encounter another group, it is disconcerting for them to leave the first record "open".
If they press the plus sign to start a new record, but don't have another encounter before the end of the hike, that blank record (which has required fields) prevents them from submitting the survey. Some people were able to figure out to go back and use the trash can to delete the blank record. But others were flummoxed and the best they could do was save the survey in Drafts and contact me about what to do.
I encourage people to use the triangle button at the top of the repeat block to collapse the repeat block after each encounter. But then when they have the next encounter, the plus sign is no longer visible and they have to reopen the block using the triangle and scroll down to the end of the previous record to find the plus sign to start a new record. But this was also less than intuitive and I got negative feedback on the whole process.
I'm in the process of deploying a new version of this which will have multiple repeat blocks, in addition to Encounters, such as campsite conditions, trail issues etc. Users will need to move among different repeat blocks depending on what type of condition they run across and need to create a record for. I anticipate this "how do I finish the record and close the block?" confusion to be even more of an issue.
Ideally there would be a way to confirm the completion of each record in a repeat, which could be set to return the repeat block to its initial appearance state: closed, with the label and a plus sign. Pressing the plus sign would open the block and start a new record, just as with the first record. But I have searched the internet, the S123 documentation and this forum without finding a way to do this or otherwise control the behavior after a repeat record is completed.
Is there a setting, tool, calculation, incantation or workaround that could be used to give the user a more positive way of completing the record and, ideally, closing the block and returning to the initial appearance, or at least approximate that? Any suggestions you might have would be very welcome.
Dave
