Since I've upgraded to the patch of Arcgispro 3.5.4, I am experiencing crashes when exporting to aix whereas before never. An .aix file is created after about 5 mins of processing, the .aix file is created and only amounts to 4kb's and the program crashes and pop-up appears where I can notify esri and provide details. I provided info many times.
What I've tried:
Clear display cached, after completing content and layers changes in layout (for example, adding layers to Legend in layout) I save project and close layout and re-open it, removing layers in the cloud and making them local when possible, changed dpi setting in export window, close map and layout and reopen just before export. I have gone through the arduous task of turning off/on layers and I found one layer was problematic which I replaced. I thought success, but the crashes continue.
Our organization uses onedrive to sync with content which is in the cloud and I understand this can be an issue. For a while, I theorized a feature layer maybe locked which caused the issue, but I am watching and exporting when all is sync'd.
Any help would be appreciated, again this is a new behavior, I've never experienced this crashing before 3.5.4.
Thanks for any thoughts,
Hylon
