I was analyzing this query,
SELECT ASSETGROUP, OBJECTID, 1 SHAPE, WATERLINE.SHAPE.points,WATERLINE.SHAPE.numpts,WATERLINE.SHAPE.entity,WATERLINE.SHAPE.minx,WATERLINE.SHAPE.miny,WATERLINE.SHAPE.maxx,WATERLINE.SHAPE.maxy,WATERLINE.rowid as rowid$ FROM WATER.WaterLine WATERLINE WHERE WATERLINE.rowid IN (SELECT MB_.RID$ FROM (SELECT /*+ LEADING(A) USE_NL(B) OPT_PARAM('_B_TREE_BITMAP_PLANS','FALSE') */ B.ROWID AS RID$,B.SHAPE,ROW_NUMBER() OVER(PARTITION BY B.OBJECTID ORDER BY gdb_from_date DESC) rn, gdb_is_delete FROM (SELECT /*+ LEADING(WATER.WATERLINE) */ DISTINCT OBJECTID FROM WATER.WATERLINE WHERE SDE.ST_EnvIntersects(WATER.WATERLINE.SHAPE, :1, :2,
, :4) = 1 ) A, WATER.WATERLINE B WHERE A.OBJECTID = B.OBJECTID AND ((gdb_branch_id = 0 AND gdb_from_date <= :specific_moment ) )) MB_ WHERE rn = 1 AND gdb_is_delete = 0 AND SDE.ST_EnvIntersects(MB_.SHAPE, :1, :2,
, :4) = 1) ORDER BY OBJECTID ASC
and I found two critical issues that I didn't quite understand.
1. gdb_from_date <= :specific_moment Why is this being asked? The database is severely affected in resolution for almost 20 hours (I had to forcefully abort the query)
2. /*+ LEADING(A) USE_NL(B) OPT_PARAM('_B_TREE_BITMAP_PLANS','FALSE') */
These hints appear to date back to ArcGIS 10.x.
In Oracle 19c/21c, they often degrade the execution plan, especially with joins on large tables.
The database is Oracle 21C.
Virgilio
