Hi everyone!
I have a print widget in experience builder failing to print in Microsoft Edge. The strange thing is that it works when you use Google Chrome or incognito mode in Microsoft Edge. The server that runs the print service states the error message below in the logs when the failed print requests occur. This occurs for both the Esri print service that is installed with Enterprise and a custom print service I created with custom map templates.
"Error executing tool. Export Web Map: Failed to create layer from service"
If anyone has experience dealing with this, please share what your solutions were! I mean, having folks use a different browser or incognito are workarounds, but if there is something I'm missing to fix this so you can use experience builder printing anywhere would be great.
Thank you!!
Also, this looks to be a bug from a bit ago and this is a post I found regarding it:
Previous Post: Portal Print Service Doesn't Work Unless Feature S... - Esri Community
