Just upgraded to 11.5 Enterprise and republished features into the portal and I am now getting a data source error on my dashboards. Do I have to reconfigure the connection to the new feature layer and reconfigure the widgets/indicators or is there any easy way out of this?
Thank you
Did you overwrite it maintaining the layer IDs? If they weren't the same then it probably did break.
https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/assign-layer-ids.htm
I overwrite layers constantly after a schema change and I've never had to reconfigure my applications.
https://ago-assistant.esri.com/
If updating your map doesn't work and you have new ID's you can update all the item ids in the JSON files of the dashboards through online assistant. It can be a pain but faster than recreating the dashboards...
The layer was overwritten in ArcGIS pro, new to Enterprise so still figuring stuff out, thank you!
We did republish from Pro. How would I go about doing this? For the web map that is connected in the dashboard, would I remove the "broken" layer and add the republished one?
Hey @Joshua_Moreno
When you say republished features into the portal, is this from Pro? If so, they may have gotten disconnected or inherited a new ID, I would attempt to reconfigure the connection with the republished features to verify that it is able to reconnect, hopefully the widgets be waterfalled from the reconfiguration and it will settle in correctly!
Cody
