Hello. I am attempting to install the "arcgis" package via the PyCharm package manager. The package fails to install with this error:
C:\Users\mshanaghan.URI\PycharmProjects\PythonProject\.venv\Scripts\python.exe C:/Program Files/JetBrains/PyCharm 2025.2.1.1/plugins/python-ce/helpers/packaging_tool.py install arcgis
Collecting arcgis
Using cached arcgis-2.0.0.tar.gz (3.7 MB)
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'error'
error: subprocess-exited-with-error
python setup.py egg_info did not run successfully.
exit code: 1
[16 lines of output]
File "<string>", line 2, in <module>
exec(compile('''
# This is <pip-setuptools-caller> -- a caller that pip uses to run setup.py
...<32 lines>...
exec(compile(setup_py_code, filename, "exec"))
''' % ('C:\\Users\\mshanaghan.URI\\AppData\\Local\\Temp\\pip-install-_h_jjf2z\\arcgis_4e3b3fcda0fb47ee99a955ab8f033458\\setup.py',), "<pip-setuptools-caller>", "exec"))
File "<pip-setuptools-caller>", line 35, in <module>
File "C:\Users\mshanaghan.URI\AppData\Local\Temp\pip-install-_h_jjf2z\arcgis_4e3b3fcda0fb47ee99a955ab8f033458\setup.py", line 193, in <module>
_get_rel_site_packages_dir() + "arcgis/gis/_impl"
TypeError: unsupported operand type(s) for +: 'NoneType' and 'str'
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
Encountered error while generating package metadata.
See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
Process finished with exit code 1
I am using a virtual environment python interpreter. Any suggestions are appreciated. Thank you.
