I am using a Data Expression in ArcGIS dashboard. It returns a Feature Set and is displaying properly in my List widget. How can I configure the Actions so that my Map widget will Pan / Zoom / Flash when a user clicks on an item in the List Widget that is using the Data Expression?
The Map widget is a web map that has similar data and includes the same ID column from my data expression. I can successfully use the Action --> Filter option since it allows me to select a Source and Target, but for the Pan / Zoom / Flash I can only select a the Map, no option to specify a source and target. So of course, turning those options on does nothing for the Map.
