I created a stormwater utility network using Esri's utility network solution. I want to add a layer of catchments that act as containers for all other features in the network. The utility network solution doesn't have such a feature so I tried to add a custom one using the following process:
Create feature class in utility network solution asset package
add subtype and asset type field and associated domains
append my catchment data to this feature class
run "Apply Asset Package" tool (with and without checking the Post Process box)
So far this hasn't been successful. I get various errors such as "network topology must be enabled," "network topology must be disabled", and once, a utility network without the catchments incorporated.
So, I'm hoping there is proper workflow for adding a custom feature class to an established utility network that someone may help me with.
Best,
Aaron
