my name is christoph schnell. i assist my local municipality with ubanisation registrations of properties. we have a database with all the properties and would like to create a map where the data shows when you click on a property. How do I go about working with ESRi to achieve this objective.
Hey @cwschnell
Great to have you in the community! From your description, this is exactly something that Esri would be able to assist with.
Does your municipality have access to ArcGIS Online or ArcGIS Pro? If so, you can create maps with the specific data tied to polygons or points, which then once clicked show the information. ArcGIS Online will allow you to create customized Web Maps, which allow you to share with others publicly or within the organization. ArcGIS Pro gives more ability to edit and manipulate data to work with, but it is not entirely needed if you're able to pull your database into a shape file, and upload it onto ArcGIS Online!
Cody
Welcome, @cwschnell!
Consider Esri Community to be your go-to spot for discussing all things GIS — a virtual gathering place where you can find solutions, share ideas, and collaborate to solve problems with the help of members from all around the globe.
Please be sure to check out the following Community-use resources to get you started:
Thanks for chiming in, @CodyPatterson! Christoph, if you need any additional help outside of @CodyPatterson's response, please let me know!
Welcome, once again!
