Hi, I have a property polygon layer that I want my user to be able to select on the map in field maps, copy that read only polygon to a new editable property survey layer and fill out some attributes and an inspection record (in a related table). The user can do that using the copy button but I was trying to make it a bit nicer/slicker. Is it possible to add a link in the property polygon popup that will automatically copy the polygon into my property survey layer and bring up the form for them to fill in the details and related inspection details? Thanks
