I'm experimenting with the new Related Records popup element.
I've added the points to my map and added the element. The related records table is not in the map.
The related recrods are using some display field that is null in most cases. I'd like to change it to a different field, such as Date, which is also the way I've set the records to be sorted.
How can I change the display field here?
