Requires the use of the "Advanced ArcMap Settings" utility available in ArcMap.
However, this functionality is currently not available in ArcGIS Pro. Therefore, we would like to request that this capability be added to ArcGIS Pro to work in the same way as it does in ArcMap.
https://desktop.arcgis.com/en/arcmap/latest/get-started/administer/advanced-arcmap-settings-utility.htm
@SunkubbDev Thanks for the idea.
Hi @SunkubbDev! As @AyanPalit noted in his comment, most of this should be available through the ArcGIS Pro project and application options. Could you update the Idea to specifically note what functionality is missing and the use case behind it? Thank you.
Hi @SunkubbDev! This Idea has been set to "Needs Clarification" for a bit. We haven't received any additional information / details so I will be closing the thread. For more information on project and application settings for ArcGIS Pro, please refer to the relevant documentation here: https://pro.arcgis.com/en/pro-app/latest/get-started/options.htm
Connectez-vous pour publier, suivre du contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
