Hi all,
What I would like to do is create an AGOL map that has a few simple polygons and a search function where I can input a pair of coordinates and have it show the location on the map. The goal is to be able to quickly check coordinates to see if they fall inside or outside of the simple polygons. Is there a good way to do this?
Thank you!
Michael,
you could just add the polygon layer to my widget.
Javascript API - Location Widget
Just type in your coordinates to the left and it will take you to it. If you have your polygon layer added, you will see if the coordinates fall in them.
Tim
Hi Tim,
I have been playing around with your app a bit and I think this is something that would work great for me but I have a couple questions:
1. The location search doesn't work for me and the "Switch Basemap" menu is empty when it drops down. Did I do something wrong? I just saved the html file to my machine and opened it in a web browser.
2. Is there an easy way for this app to drop a pin on the input coordinates (similar to how Google Maps does it) so I caould easily see where the location is in addition to the window pop-up?
Thanks so much!
you have to copy the html file into the following folder:
C:\inetpub\wwwroot
And then open a browser and type the following.
http://<your computer name>/location.html
It will only work right, if you use your pc as a server.
If not you can always use my jsfiddle to test: Location, Location, Location... - JSFiddle
Hope this helps!
Oh, you have to serve the page to get it working correctly. I'll give it a shot!
