We have a Feature class in the project default fileGDB, we enabled "start/stop" edit mode in Pro 3.3.5. The issue is as follows for Calculate Geometry:
- If we start editing > open the table > r-click on a field and run "Calculate Geometry": Once complete, both Save and Discard buttons are still greyed out. When you click to stop editing, you aren't asked to save edits, and all Calculate Geometry edits are lost. The only workaround is to do a manual edit afterwards, then save.
- If we start editing > open the table > r-click on a field and run "Calculate Field": Once complete both the Save and Discard buttons are enabled. Works as expected.
Assuming a bug and a trigger of some type just isn't running in this specific scenario. Others notice this issue as well?
