i have an experience builder app which has a map and the map has 4 layers in it, i want to clone the app and the map and only 1 of the 4 layers and then to remap the cloned feature service into the cloned map.
i've tried this but it copies all 4 layers, i even tried the item_mapping and used the same id as both
from pathlib import Path
import sys
import pandas as pd
from arcgis.gis import GIS, Item
from arcgis.env import active_gis
from arcgis.features import FeatureLayerCollection
from arcgis.mapping import WebMap
source = GIS("home")
print(source)
target = GIS("home")
print(target)
group = source.groups.search("id: 8d..fd")[0]
for item in group.content():
print(item['title'])
print(item['id'])
xid = item['id']
items = source.content.search(query="id:{0}".format(xid))
#items
for item in items:
try:
print("Cloning " + item.title)
copy_list = []
copy_list.append(item)
print (copy_list)
if (item.title == "In_Map"):
item_mapping = {"db..d77" : "db..d77"}
target.content.clone_items(copy_list, copy_data=True, search_existing_items=True, item_mapping = item_mapping, folder="In_Map_Test_version")
else:
target.content.clone_items(copy_list, copy_data=True, search_existing_items=True,folder="In_Map_Test_version")
print("Successfully cloned " + item.title)
except Exception as e:
print(e) any ideas?
