Sadly I somehow had a tsx file deleted from a custom widget and I am not able to recover it. i have an older version but if I use that I lose 2 days of work from changes I made. I have a compiled copy of a widget from a distribution. When I import the map back into eXb Dev from the deployment zip the widget shows back up but it is not decompiled back into my custom widgets folder. Does anyone know a way to decompile a widget using webpack if even possible?
It will be referenced in both of these files in every app its used in. Good luck!Edit: Maybe starting with a clean download of Experience Builder would be easier.
Good news is i found VS code kept a history and I was able to recover code. Now the problem is experience builder seems to have a cached version of the widget even though it is not in the custom widgets folder. When I put updated code in that folder and restart webpack it states it is a duplicate name and doesn't load the new one. I can't figure out how to remove the old code. Assuming it is buried in some config somewhere.
