Hi everyone,
I am looking to return the subtype domains associated with a subtype field. I was able to explore arcpy.da.ListSubtypes however this function seems to return a dictionary and I seem to be getting lost thereafter. Is there a quick way to isolate only the subtype domains from the dictionary?
Thanks!
There is a good sample on the resource center that will list all the fields, their default value, and any domain assigned.
import arcpy fc = <FeatureClass> subtypes = arcpy.da.ListSubtypes(fc) for stcode, stdict in subtypes.iteritems(): print('Code: {0}'.format(stcode)) for stkey in stdict.iterkeys(): if stkey == 'FieldValues': print('Fields:') fields = stdict[stkey] for field, fieldvals in fields.iteritems(): print(' --Field name: {0}'.format(field)) print(' --Field default value: {0}'.format(fieldvals[0])) if not fieldvals[1] is None: print(' --Domain name: {0}'.format(fieldvals[1].name)) else: print('{0}: {1}'.format(stkey, stdict[stkey]))
However, if you are only interested in a list of all the domains used within the subtype, we can just list the domains using a similar code:
import arcpy fc = <FeatureClass> subtypes = arcpy.da.ListSubtypes(fc) for stcode, stdict in subtypes.iteritems(): print('Code: {0}'.format(stcode)) for stkey in stdict.iterkeys(): if stkey == 'FieldValues': print('Fields with Domains:') fields = stdict[stkey] for field, fieldvals in fields.iteritems(): if not fieldvals[1] is None: print(' --Field name: {0}'.format(field)) print(' --Domain name: {0}\n'.format(fieldvals[1].name)) else: print('{0}: {1}'.format(stkey, stdict[stkey]))
Output:
Code: 1 Default: True Name: Metal Pipe SubtypeField: SubTypeCD Fields: --Field name: InletWallThickness --Domain name: fcNumericWallThickness --Field name: Material --Domain name: fcMetalMaterial --Field name: PipeDistributor --Domain name: fcPipeDistributor
The logic of this code is still sound, users will just need to replace instances of .iteritems(), iterkeys(), with .items() and .keys() for ArcPro/Python3 processing.
Hi, hoping that you are in good health. I need your support to review below code. Using ESRI ArcGIS Desktop version 10.4.1, a file Geodatabase having line feature class "Trench" with two tables "T_DUCT" and "T_SUB_DUCT".
Requirement: It is required to create sub type records of "T_DUCT" inside T_SUB_DUCT (as ROWS). Is there anything need to update in below code?
I have attached the code file.
Regards.
Khalid Mahmood
Riyadh, Saudi Arabia
kmc786pak@gmail.com
thank you!
