I'm having issues adding data to my ArcGIS Pro map. All the data works perfectly fine when brought over to ArcMap. One of the tables has a geometry field calculated in SQL. Another table has a geometry field and an assigned ObjectID field. Both tables are in a regular database table.
68026rc
BUG-000107137: "Error: Failed to Add Data" is encountered when adding a table with no NOT NULL columns in ArcGIS Pro 2.0.
Radoslaw,
Can you elaborate more on the problems you are having? Is there an error message? Can you post a screen shot?
68026rc : Could you confirm the following:- Does the tables have any column which does not allow NULL values?
- Try to add the tables using ArcGIS Pro 1.4.x, is the issue still encountered?
