Hello everyone,
I am having the following problem.
I have a parent feature layer (globalID) and 4 child tables (parentGuid).
I wrote this simple arcade expression to access the related table attribute:
var relatedrecords = OrderBy(
FeatureSetByRelationshipName($feature, "TabellaDifetti"),
"Data DESC"
var cnt = Count(relatedrecords);
var output = "";
if (cnt > 0) {
var info = First(relatedrecords);
output = 'etichetta: '+ info.Numero_albero
return output;
It works fine for 3 tables but not for the last one. I get the following Result: Test execution error: Unknown Error. Verify test data.
I am sure that the problem is in the table and not in the code, but I cannot imagine what it could be.
I have checked:
- the relationship is the same for all the 4 tables (simple, 1:M, forward) built in ArcGIS Pro and shared in AGOL
- I can see access to the related table from the parent feature
- the table should not be corrupted: I accessed to the record directly from the popup of the layer table and I can read it (using $feature.Numero_albero)
- I try to output the Text(info) and I get the same error...
This table has 1250 records and 1250 record, the type is integer or string and one date. The only difference from the other one is that the strings are 8000 character long, but ...the problem is also present with the numeric type.
Do you have any suggestion that I can check?
Thanks, carla
