In the Geolocations Details section of the report delta values are given for GCPs and Checkpoints. The delta value for check points give deviation for the outputs - check point coordinates. The delta value for the GCPs give deviation for adjusted GCP to original GCP coordinates. The resulting outputs at the GCP locations can have more/less deviation at the GCP than the delta of this GCP deviation. The report is not clear that the delta values in the same section of this report mean very different things. Can the GCPs be added to a section like the check points? It would show the delta values from the output DSM to the GCP coordinate.
Connectez-vous pour publier, suivre du contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
