Hi all,
I'm trying to connect ArcGIS Enterprise 11.2 with Power BI, but I keep getting the error: "The specified URL is not valid."
Here are my some details:
Has anyone faced a similar issue? Are there any additional configurations needed ?
Thanks in advance!
Hi @AbdelrahmanGhazaly,
Thanks for your question! Could you please check this link and see if it helps?
https://doc.arcgis.com/en/microsoft-365/latest/power-bi/configure.htm
Thanks a lot @NaZhang_Esri now it's working, I've another issue but I will post it as a new post if you've experienced it,After login to my enterprise using BI, map cannot be displayed and error message appeared:
The basemap is unavailable or has been deleted from the server. Reset the map.
when I try to explore the content no issues but when I try to view layer or map I got the above error
I'm glad it worked! For the basemap error, could you please try to sign in to your Enterprise portal first then view it? I guess the credentials are cleared when you view the report. Please let me know if this doesn't work. Thank you!
