Question 1: Differences between Importing XML and Using Python Scripts for AIS Database Configuration
When configuring the AIS database, I found two methods:
Directly importing from XML.
Creating using Python scripts.
Is there any difference between these two methods?
Question 2: Issues Encountered While Creating a Simple Chart
Can you help me identify the issue? My workflow is as follows:
I have successfully created the AIS database.
I downloaded data from
Data Sets Germany and successfully used the
Import AIXM 5.1 Message tool to import the data, which shows as points (about 1550 records) in German airspace.
When I used the
Generate Aviation Cartographic Features (Aviation) tool, I set the
Source Feature to
ADHP and the
Target Feature to
ADHP_C. After running the tool, there were no records in
ADHP_C. The tool execution prompt see below 。What could be the reason? Did I miss any settings or steps?
Tool Path
Source and Target Cartographic Features ENCO\ADHP ENCO\ADHP_C
Area of Interest Features ENCO\AIS_AOI
Extraction Query Table
Cartographic Exceptions Table
Updated Cartographic Feature Classes ENCO\ADHP_C
Messages
Start Time: 2025年3月11日 16:27:56
Skipping cartographic feature generation for AOI feature 1 due to incomplete attributes.
Succeeded at 2025年3月11日 16:28:02 (Elapsed Time: 5.83 seconds)
