Hi Community; A question pertaining to importing mxd projects into a new Pro project. I have a very nice but older mxd map project (and all of its supporting files) that I am hoping to import into and create a Pro gdb project from. Following the instructions at
https://pro.arcgis.com/en/pro-app/3.2/get-started/migrate-existing-work.htm
I have found many of the data layers in the Layout Map Frame and the Map itself have broken data source file paths. What seems odd is that under Properties when looking at the Source, the file path is to an Access mdb. Now I have that mdb but it is not reading from it correctly? Frankly I didn't even know one could source and Access mdb for layer feature definitions. Now I also have the shapefiles for the corresponding layers and resetting the source path to them just fails. And Pro of course doesn't directly read from an mxd so that doesn't work either. Redefining the source is being elusive.
Any thoughts or ideas on this?
Thanks;
Dave
