Can anyone tell me where to find the AGOL logs for Data Collaborations? I have a collaboration from Enterprise Portal to AGOL that is failing on one collaborated data service. I know there is a log I can view that will let me know which dataset is failing........ just can't find it....
Hey Felix
It would be worth checking the Portal for ArcGIS Logs (documentation). Generally most issues are flagged under the Severe level errors.
If you can identify a specific timestamp that collaborations are failing in then this will help filter any noise out of the logs.
In regards to troubleshooting I would also try rebuilding the collaboration, as this is usually the quickest way to resolve issues.
Hope that helps
David
