hello,
I am brand new to the survey123 world. i am hoping to build a survey to be used offline. the data to be collected is tree diameter and health. i have a CSV file that has the data from a pervious inventory. i attached a simplified version of it. the idea is to go the field (no wifi/cell) select a location from a site list. then select a plot from a list based on the location. not all locations have the same plot numbers or number of plots. That then would create a repeat group with all the tress found at that location in a given plot. the concept seemed simple but i am getting no where with the samples or videos.
I started with pulldata in the calculation column but if i read that correctly i can't filer by location and plot because those values repeat.
then i moved to search() in the appearance column. i failed to get that to work.
i was envisioning lots more functionality but i struggling with what i thought would be easy..
i completed several trainings and watched a number of videos. I have been working through the blog post and forum posts.
there is no spatial information included in this survey.
i also realize that there are likely many ways to solve this.
any and all help welcomed
thanks
j
