Hi, I want to be able to see a PDF, Excel, Word etc. when clicking an object in Experience builder.
Ideally I want it from sharepoint, but I've also tested with OneDrive and Google Drive. It get's from getting outside of experience builder.
I had a similar setup with the old Operation Dashboards, where, clicking a feature opened up a Sharepoint projects folders, or even Excel files, directly inside of Operation Dashboard. I'm not sure if I forgot what I did or if the possibility changed with JavaScript 4.x, or if Microsoft changed something. Or if this company simply has a more strict setup.
Ideally you'll create files, where the file name is equal to an attribute in the object. The you use the long sharing code in an embed widget, where the URL then updates from the sharing code and the attribute.
Any ideas on that, is that a dead end now?
