We found that there are quite observable changes in MapView when we set the Viewpoint using the same Envelope
Please see attached images.
The coloured rectangle is an GraphicsOverlay inside ArcGIS
The line with 2 circles are drawn on top and of the map, and they do not move between versions.
Note that only the map(and rectangle) is different between versions even with the same viewpoint.
This is the code we use:
mapViewProxy.setViewpoint(Viewpoint(boundingGeometry: Envelope(center: center, width: size, height: size)), duration: 0)
With these variables:
center = Point(latitude: 47.38776035242992, longitude: 8.6554592857211)
zoomedInSize = 0.00034594444524398035
zoomedOutSize = 0.0010085843884744825
We have been using ArcGIS since v100, and only in v200.6.0 is this change observed
Is this a bug? Or perhaps something changed with the way MapView is rendered?
