I am working on an arcade script to auto calculate the next sequential AssetID for any new features. The existing features all have a unique AssetID in the form: MH.12345
The script I have so far is being plugged into the smart form for the feature as a calculation for the field AssetID. The idea is to ONLY have an assetid generated when a new feature is created. The problem I have is when I go to edit a feature with an existing assetid, the assetid is wiped and set to a null.
My code is below:
// If this feature already has an assetid, return the existing assetid
if (!IsEmpty($feature.assetid)) {
return $feature.assetid
// Verify if this is a new feature
if ($editcontext.editType == "INSERT") {
// get the feature with the greatest assetid
var id_features = Filter($layer, "assetid IS NOT NULL")
var max_id_feature = First(OrderBy(id_features, "assetid DESC"))
// For an empty featureset, return the first assetid in the dataset
if (max_id_feature == null) { return "MH.00001" }
// Calculate and return the next assetid
var max_id = max_id_feature.assetid
var next_id_number = Number(Replace(max_id, "MH.", "")) + 1
return "MH." + Text(next_id_number, "00000")
// If none of the above conditions are met, return null to do nothing
return null
What am I missing that would allow me to insert the next assetid but not touch or modify existing assetid values?
Thanks in advance.
UPDATE:
I also just updated the code to include an if statement for editType == "UDATE" and the script is still behaving the same. Code is below:
//if (!IsEmpty($feature.assetid)) {
// return $feature.assetid
// If the feature is being modified, return the existing assetid
if ($editcontext.editType == "UPDATE") {
UPDATE 2:
Slight modification to clean up the code and added elseif statements:
// Preserve the existing assetid if it already exists
return $feature.assetid;
} else if ($editcontext.editType == "UPDATE") {
// If the feature is being updated, explicitly return the existing assetid
} else if ($editcontext.editType == "INSERT") {
// If this is a new feature (INSERT), calculate a new assetid
var id_features = Filter($layer, "assetid IS NOT NULL");
var max_id_feature = First(OrderBy(id_features, "assetid DESC"));
return "MH.00001";
var max_id = max_id_feature.assetid;
var next_id_number = Number(Replace(max_id, "MH.", "")) + 1;
return "MH." + Text(next_id_number, "00000");
// Default behavior: return null to avoid overwriting the assetid
Still not working as expected.
