I am trying to install version 3.2.1. I believe this is the previous version. I'm running into un-degabble errors with 2.4.0 and so want to run a prev version. The docs don't explain anything.
I am using pipenv, and the issue may lie here as I am not sure the exact syntax for exact versioning.
What I've tried:
pipfile
[[source]]
url = "https://pypi.org/simple"
verify_ssl = true
name = "pypi"
[packages]
arcgis-mapping = "*"
pyreadline3 = "*"
[dev-packages]
[requires]
python_version = "3.12.0"
With pipenv shell running with 3.12.0 virtual env, and which python showing 3.12.0. Deleting lock file does not help.
$ pipenv install arcgis~=2.3.1
RuntimeError: Failed to lock Pipfile.lock!
I also tried plain pip:
$ pip install arcgis~=2.3.1
ERROR: Ignored the following yanked versions: 1.8.5.post1, 1.8.5.post2
ERROR: Ignored the following versions that require a different python version: 2.0.1 Requires-Python >=3.7, <3.10; 2.1.0 Requires-Python >=3.7, <3.10; 2.1.0.1 Requires-Python >=3.7, <3.10; 2.1.0.2 Requires-Python >=3.7, <3.10; 2.1.0.3 Requires-Python >=3.7, <3.10; 2.1.0.4 Requires-Python >=3.7, <3.10; 2.1.0.5 Requires-Python <3.10,>=3.7; 2.2.0 Requires-Python >=3.9, <3.12; 2.2.0.1 Requires-Python >=3.9, <3.12; 2.2.0.2 Requires-Python >=3.9, <3.12; 2.2.0.3 Requires-Python >=3.9, <3.12; 2.2.0.4 Requires-Python <3.12,>=3.9; 2.3.0 Requires-Python <3.12,>=3.9; 2.3.0.1 Requires-Python <3.12,>=3.9; 2.3.0.2 Requires-Python <3.12,>=3.9; 2.3.0.3 Requires-Python <3.12,>=3.9; 2.3.1 Requires-Python <3.12,>=3.9
ERROR: Could not find a version that satisfies the requirement arcgis~=2.3.1 (from versions: 1.3.0, 1.3.0.post1, 1.3.0.post2, 1.4.0, 1.4.1, 1.4.2, 1.5.0, 1.5.1, 1.5.2, 1.5.2.post1, 1.5.3, 1.6.0, 1.6.1, 1.6.1.post1, 1.6.2, 1.6.2.post1, 1.7.0, 1.7.1, 1.8.0, 1.8.0.post1, 1.8.1, 1.8.2, 1.8.3, 1.8.3.post1, 1.8.3.post2, 1.8.4, 1.8.5.post3, 1.9.0, 1.9.1, 2.0.0, 2.4.0)
ERROR: No matching distribution found for arcgis~=2.3.1
This clearly says 2.3.1 Requires-Python
.12,>=3.9, and I'm using 3.12. How can I switch to it?
Pip says that version does exist.
