Hi all,
I am working on a script to create map booklets for local fire agencies. Each fire agency covers a different area of the county, and each will get their own map booklet. Essentially what I want the script to do is iterate through the fire districts (FDs) feature class, selecting the map pages features that intersect, then iterate through those map page features, exporting a PDF for each FD. I already have a script that does something similar for the entire county, but I need help with the double loop logic here (or maybe there's an even better way?). Here's what I have as a very rough draft that I know doesn't work:
aprx = MAP.ArcGISProject(aprx_file)
lyt = aprx.listLayouts("AtlasPage")[0]
mf = lyt.listElements("mapframe_element", "Atlas Map Frame")[0]
mapX = aprx.listMaps('FireAtlas')[0]
FDs = mapX.listLayers('Fire District Boundary')[0]
pages = mapX.listLayers('Section Pages')[0]
with arcpy.da.SearchCursor(FDs, 'FireAgency') as FDcursor:
for row in FDcursor:
FD_loop(row, aprx, gv.data_path)
agency = row[0].replace(" ", "")
agency_path = os.path.join(gv.output_path, "{}".format(agency))
if arcpy.Exists(agency_path + os.sep + "OutputX.pdf"):
os.remove(agency_path + os.sep + "OutputX.pdf")
select = "FireDistrict = '{}'".format(row[0])
arcpy.SelectLayerByAttribute_management(FDs, 'NEW_SELECTION', select)
arcpy.SelectLayerByLocation_management(pages, 'INTERSECT', FDs, '', 'NEW_SELECTION')
spaFil = row.shape
spaRel = "INTERSECTS"
with arcpy.da.SearchCursor(pages, 'FDC', sql_clause=(None, 'ORDER BY PageOrder'), spatial_filter=spaFil, spatial_relationship=spaRel) as pageCursor:
for page in pageCursor:
atlas_page(page, aprx, agency_path, gv.data_path)
